Re: Getting my Hobbit up to Par
If you must use the decomp that is a good thing. That means that it has so much compression that you need the decomp to turn it over. The decomp just makes it easier to turn the engine over by lowering the compression. It would be a sign that you have less than idle compression if you could start without the decmp.
