Re: best bearing grease
lee's anus is leefungchowOG /
WRONG!!!! peter don't start with dry bearings.
start a motor with dry bearings and they are ruined instantly (if you are a performance tuner and you need your bearings to be awesome). if the bearing doesn't come with grease in it, then put some 2 stroke oil on them. your gas-oil mixture will lube them for the rest of their lives. any grease will just be washed out by you mixture in about an hour of riding.
