best bearing grease
I am doing a complete rebuild on my e50 and I was curious as to
what your thoughts are on the best grease for engine bearings?
This is my first complete rebuild.... at least the first time I have
basically replaced the crankshaft and bearings...and ported. I
know that the bearings are lubed by the oil gas mixture for part of
the crankshaft and the other is lubed by the ATF, but I just would
like to put it together correctly. This isn't the first time I have
cracked the case...just the first time I have replaced the bearings.
Thanks!
Re: best bearing grease
Bill, I've always used marine grease on every grease application I have. Remember that using it on the clutch side will alter the composition of the fluid. That is never a good idea. Larry
Put 2 stroke oil in the bearings and grease on the lip of the seals
Use 2-stroke oil on engine bearings and ATF on transmission bearings.
engine bearings dont need grease dude.
lee's anus is leefungchowOG /
WRONG!!!! peter don't start with dry bearings.
start a motor with dry bearings and they are ruined instantly (if you are a performance tuner and you need your bearings to be awesome). if the bearing doesn't come with grease in it, then put some 2 stroke oil on them. your gas-oil mixture will lube them for the rest of their lives. any grease will just be washed out by you mixture in about an hour of riding.
