Carburetor noob Q&A
Hex Inverter /
Hey guys,
I'm still new to the whole performance side of mopeds.
I've got a couple questions that are pretty general.
1.) Is it possible to fit a Dellorto carburetor to any type of engine? What type of intake should I look for in size relating to the carburetor size?
2.) Are the cable connections usually pretty generic and easy to fit to a new carburetor?
3.) The idea would be to get a larger intake carb, right? If so - are there any other things I need to do when getting a better carb for the engine to run - or is it just a given that it WILL run no matter what carb is on it (assuming it's fitted/working properly)?
Any info is much appreciated. Thanks!
