Smoke from my new 70cc kit?
Alright, i got my moped from a buddy of mine intending to do some performance work. I just did the 70cc airsal kit, jetted the stock carb to 68, UNI green filter, and now it puts out white smoke from the bullet exhaust. Could i be running the wrong spark plug or something? Its an NGK B6HS. Maybe the carb needs to be tuned? Its runs AMAZING, its just smokey haha
Re: Smoke from my new 70cc kit?
John Joedicke /
White smoke indicates you are burning transmission fluid. crank seal blown out or worn.
white smoke could also be just jetted rich...
Pull your spark plug and see what it has to say about it
Cory (mrdr 133) /
white smoke could also mean that you might have just put in too much oil...simmer down you nay sayers...it probably isn't that big of a deal
Yea, i just went and checked the plug. It looks fine to me, no white residue, just a little bit of an oily coating. But the thing is, i havent done anything with the oil. I just out the kit on and jetted it, and that was it...
Cory (mrdr 133) /
yeah it's just an off ratio of oil/gas. you might have just put too much in, i do it all the time when i fill up at the pump and drop the oil in. no biggie, better to over oil, than to under oil
and plus gas evaporates and oil does not so as it sits in the tank the mix will be gradually get richer.
I think he is using his auto oil injector, I assume he is running a tomos, but I guess it could be a puch.
Yea im using an injector, its a tomos.
This is it
sure its not just being a 2 stroke?
I dunno, it could be. I'm a landscaper and usually if white smoke comes from a 2 stroker, its usually too much oil being burned. So maybe being a higher jet, means that its getting enough lubrication from fuel, and not needing the oil thats getting injected, thus getting burned off?
white smoke is tranny fluid..
too much 2 cycle oil will be blue/black.
So in that case, just replace the crank seals?
Alright, so i loaded the bike into my truck tonight and took it to my buddys house right by a 1/4 mile long causeway. We took turns rippin it up and down there. Top speed out of the both of us over the course of the night was around 55-60 in a 25 haha no joke. I think i just had to break in the cylinder rings because it doesnt smoke at all anymore. Its not insured or registered yet, thats why i havent made any successful runs with it yet. But now, no worries, no more smoke, it runs AMAZING
Man!!, I was getting excited by those speeds untill I saw you ride tomos and not puch. I am still thinking about getting this kits. Folks say its a good beginner.
yeah how were those speeds clocked?? Hopefully not by the tomos speedo.
:-[ yes by the tomos speedo haha, i plan on gettin a trail tech
you'll be surprised how fast you are actually going once GPS'ed properly. I would say....45 max.
_you’ll be surprised how fast you are actually going once GPS’ed properly. I would say….45 max._
TRUE!
did you even break it in first?
Ooh its broken in now! it runs like a TOP! I think it even runs better than it did with the 50cc stocker.
sure it does. white smoke is usually the burned crap that has been stuck in the exhaust for some time. the kit is just powerful enough to burn the crap out.
