Re: Minarelli V1 Suggestions
Mike Thomas /
Yep the v1,s are one kickers, or should be. check your points, then condenser...condensers seem to be a cause of loooooooong pedal starts... Ten bucks says you seize with an 86, census is shit, the plug tells you what you need.
