Puch Maxi Luxe- 16mm Delorto and Techno Boss carb
Zack Rineer /
I have done research and found a little but I would like to know if anyone is running this setup and what they gained from it.
What can I expect to gain?
What jets should I get?
I am very serious and if I get pleasing answers I will most likely order. :)
Re: Puch Maxi Luxe- 16mm Delorto and Techno Boss
Zack Rineer /
Ahhhh not techno boss carb! **pipe!!
Zack Rineer /
I swear im sober..
**Dellorto
I have the tecno boss on my korado. It robbed the lower end power from it, but above 20mph it flies.
My square bing carb says 18 on it which I assume is an 18mm carb.
Zack Rineer /
do you know your top speed?
try the tunning page and see what people are doing!
http://spreadsheets.google.com/ccc?key=p_Ysahl1B79WHMUBbvCzNfg
my only suggestion on fixing up your ped is spend a lot of time on this site. and make the wiki and search tabs your best friends. there are a lot of set ups you could be doing and as i have found out you can take 2 puchs with the same set up and get 2 different top speeds there is so many factors that go into your ped. i wish you the best of luck my friend...
Zack Rineer /
thanks greg!
I think its a great, comparitively cheap, first time performance mod!!! you should get 35-40 mph depending on gearing!! i run a 73 jet on 16 del, 4p homoet on korado e50!! 38mph!!
Zack Rineer /
This is the answer I was waiting for!!!!
Thanks Rob.
When im pissed off tonight after my 3 hour english class I might order this set-up to cheer my ass up..
