piston window
Tyler Jacobson /
so does a piston window only work on a reed valve intake?
Re: piston window
It all depends on the porting. Some piston ported cylinders have boost ports and small holes in the piston which match up to them.
Re: piston window
Tyler Jacobson /
do you know of an example or have photos of piston ported cylinder with boost ports or piston windows?
Re: piston window
Malossi, eurokit,athena, k-star, for example. Check them out here http://www.mopedarmy.com/wiki/Puch_Maxi_Cylinder_Information
