Dellorto SHA Air Filter
I recently swapped out my leaky Bing for a 15mm Dellorto SHA on my Maxi and am trying to figure out about the air filter. I took off the black plastic cover right away and then tuned it in pretty well with a 65 jet. It was 4 stroking a little with a 67 jet so I tried removing the metal mesh and now she rips...Is it a bad move to run it without any filter or is there some other mod that you've done to allow maximum air without the dirt getting in? Thanks.
Re: Dellorto SHA Air Filter
put a layer of panty hose over it, keep upjetting until you four stroke again, and back down one size.
if you want to buy something, this thing is SHA-specific
http://www.tayomotors.com/servlet/Detail?no=13
dan, ive got an aftermarket foam filter for dellorto SHAs that you can have. they wont fit on my moby.
oops, didnt read the post above me. thats the one (or actually three) that i have.
Just remove a couple of layers of the dellorto filter screens..
I'm too parinoid about using panty hose.. IMO is can get sucked into the carb.
uni filter material.
hoseclamp.
Thanks, Jay; I'd like to give that a try if you didn't mind. See you in the hood.
m6onz5a: That was was I was thinking but didn't see how to get the screens out without destroying the housing.
