Gazelles + Maxi ??
Will 2.5 gazelles fit the rear fender on my maxi?
i know i could search, but i wanted a specific answer.
and i'm too lazy to go try sliding the wheel on the bike...
Re: Gazelles + Maxi ??
I believe 2.5 will clear the rear fender, but they will definitely not clear the maxi swing arm. They will clear Magnum or the boxed chrome swing arms.
fabrication time!
Did the bike come with 2.25 tires or 2.00 tires?
Gazelles + Maxi ??
Gunther McCilicutty /
they will not fit on the back with your stock swing arm. Gazelles at 2.25 are bigger than the stock counterpart. Mine has about 3/36 clearence on each side using the 2.25's
Gazelles + Maxi ??
3/16 clearence...
i guess i'm either gonna try using my freespirit swingarm or just make a new one instead.
Ed, If you want to buy different tires instead. I bet Garrett would buy those off you. Otherwise I may just buy them back also.
i already fixed the problem, no biggy.
