Re: Airsal 65cc... Anything i should know?
Rob Farmer /
rich means bigger jets, more fuel!! run the 92 and work down. always check for airleaks along the way by spraying carb cleaner around intake and cylinder. if you have any fluxuation in idle, tighten it up!! make sure all surfaces are flat and use new gaskets all around!!
