Re: Motobecane Dellorto 15.15 won't idle FRUSTRATE
Silverfox Sullivan /
Where did you get the carb? If it was a used one perhaps some old fuel was left in it and it needs to be cleaned.
Check the little idle air passage on the bottom of the bellmouth.
Other than that you could have an air leak at the manifold joint?
