pull choke on dellorto
how do you use a pull choke on a dellorto carb? do you pull it up with one hand while trying to start the bike? seems like you'd need three arms. it doesn't stay up on its own, so how do ya use it? thanks!
Re: pull choke on dellorto
Pull up, twist 1/4 turn. Opposite to close.
þλ†Я¡¢k §¡§ΩИ /
hah i knew there was a trick to it.
anyone know what that screw is left of the idle screw?
or at least on my 21phbg
idle mixture screw.
do a seach in the wiki for the Dellorto manual and read it.
better read it before you do anything else. yikes.
