I've got a 2006 A55 that has several broken off mounting tabs on the right half of the crankcase.
I just received a brand new A35 case as a replacement. Problem is while I only need the one side I"m concerned they are not compatible. I'd have to ditch the electric start which is not a big deal, but I"m concerned about the ports.
I'm planning to have the ports worked on but am concerned that there's not enough meat on the A35 case.
Anyone see a problem with this set up?
