Q's on tuning carb
Frostback Ditch /
Recently there have been several performance parts introduced for the Suzuki FA50 that I will be interested in getting (mostly the exhaust and a few homemade things), and I have found that Dellorto jets swap into the main jet on my carb.
My question is this, I'd just like to know what my tuning range will be seeing as I can only run a stock pilot jet, so I will only be playing with the needle and main jet. Will the tuning of the main jet make much of a difference? What problems may arise? I'd like to be able to tune the carb at will as I was actually able to seize my bike at during the blood drive, and a dellorto swap looks like it would be hella fun to make fit.......Oh, and I will be swapping the oil injection out and going straight pre-mix, so no worries about not enough oil. Thanks in advance.
Re: Q's on tuning carb
Frostback Ditch /
Bumpity, anyone got any words of advice?
i'd like to know more about this stuff too. i just put a new OEM carb on my fa50. i've also mulled over the idea of using a different carb and getting rid of the oil injection...where have you seen performance parts? a couple years ago (before my ped's death and recent resurection) there was absolutely nothing for the fa50 anywhere except stock parts.
oh, and, hi! this is my first post.
_Kevin
Frostback Ditch /
Check up treatsHQ on ebay, Benji has some Simonini exhausts for the FA50. I was also talking to a gentleman from Quarter Kick who was saying that there is a big bore kit thats being made for our nopeds as well, can't remember the make though. The problem is, to do a big bore kit you'd want to upgrade the carb.
dellorto carbs seem like an option, i'd do more research but my eyelids are growing heavy and i still need to pack for a weeklong trip to a land with no web access.
_Kevin
Frostback Ditch /
Ya, but with those it looks like you'd have to do a custon intake, then run the chance of having to remove your reed valves. I'll look into that as well. Hope you enjoy your trip kevin.
you would have to make a new manifold, or at least an adapter. there isn't much space in there by the fender either. i know some people have done this, but i don't know if there would be anything that you could just bolt right on. i'll do some looking around when i have a chance.
