anyone try this?
after the restriction is taken out of the exhaust is this a decent pipe for the minarelli or is the estoril the only way to go?
anyone try this?
put on on a minarelli a few weeks ago, really improved the top speed
How did you get the flange to fit? I have a techno boss and the pipe is so big that even if I grind the holes in (puch pipe) there is no way in hell that I will be able to get the nuts on. They will be literally touching the out side of the pipe?
I have tried an estoril before on a V1. It helps, but not a whole lot. Also I believe Chad used some special extention nuts he had available to mount the pipe up without the header interfering with the nut. Think of a long threaded barrel with a hex head at the very end.
mopedshop.com has a kickass nut/gasket kit that makes bolting up an afetrmarket pipe super easy. The nuts go on with a 9mm socket wrench. easy peasy.
use allen bolts.
eesh, i've had those strip out before... probably wouldn't on a cast fe head.
you can find 'metric coupler nuts' at a local ace, they are like, three nut tall nuts, should clear it.
