OK...heres the deal.
All along I was thinking my Maxi Luxe had a head gasket...just pulled it off and it does not...aluminum against aluminum. I was going to pull out the gasket and sand the head down just a little bit to get better compression...not sure I should do this now. I have no clue what the compression was before I pulled off the head.
Is this a hi comp head? Keep in mind this is a Maxi Luxe 1.5 hp. Is there anything I can do to make it MORE hi comp?
It all looks pretty black in there and I plan to clean it out with carb cleaner. Will the cleaning help performance?
