Yes my piston is recessed as much as yours probably a little more so
If you do deciede you want to mill the cylinder i strongly recommend you fit a tomos head on first and then see how much play you have with playdo or something because my piston was hitting my spark plug so i had to add another spark plug spacer thing unless you plan on grinding down the piston or using some sort of weird spark plug that i dont know about lol
