muhahaha.......its pretty much done....my secret project....
heres some really crappy pics from my cell phone becuase I cant find my digital camera. maybe better pics later.
You would have to spilt the case, unlesss.......you drill a hole in the case itself!!
First Step-pull out rubber plug (need to find one that will fit in the hole, but thats the least of my worries.
You see this:
<a href="http://s26.photobucket.com/albums/c129/71_Cheyenne/?action=view¤t=IMG00177.jpg" target="_blank"><img src="http://i26.photobucket.com/albums/c129/71_Cheyenne/IMG00177.jpg" border="0" alt="Photobucket"></a>
Second step- turn back wheel so it rotates the clutch drum until you see your little acces hole.
<a href="http://s26.photobucket.com/albums/c129/71_Cheyenne/?action=view¤t=IMG00178.jpg" target="_blank"><img src="http://i26.photobucket.com/albums/c129/71_Cheyenne/IMG00178.jpg" border="0" alt="Photobucket"></a>
Third step- stick a screwdriver in the whole to hold the clutch drum in place while you turn the flywheel (you are tuning your moped, so I assume you probably don't put the flywheel cover on, never-the-less, its only two little machine screws) untill you see the adjustment screw on the clutch through both the case hole and clutch drum hole.
<a href="http://s26.photobucket.com/albums/c129/71_Cheyenne/?action=view¤t=IMG00175.jpg" target="_blank"><img src="http://i26.photobucket.com/albums/c129/71_Cheyenne/IMG00175.jpg" border="0" alt="Photobucket"></a>
Adjust away!!
Booyah.
