Re: no head gasket--safe?
Cleats Onionpockets /
Puch cylinder heads tend to be well formed enough that you can take the head gasket out and it will still seal just fine. If you take it out, put things back together, start it up, and feel air puffing out around the area where the gasket had been, tighten things down a little. If it's still doing it, you need to keep the gasket or smooth the head out so it seals correctly.
