minarelli's suck
Well, not really, but i am having the hardest time getting this motron past 31 mph... I put a bi-turbo on it, de-restricted my air-filter, re-jetted to a 64, and all I got was more noise.. I am learning the fine art of air-fuel mixture, but I keep hearing these minarellis are blasters.. I must be doing something wrong... Any ideas? thanks....dan
Re: minarelli's suck
what size carb?
what gearing?
sure a 64 is right?
Keep tuning that mofo, im telling you that even stock, my General Lazer flies...try a smaller jet like 52
You can get BIG kits for them (90cc). I'm going to be running an 80cc.
Yea, it's stock gearing.... I want to see how much I can get out of my stock 50cc cylinder before I go to a massive kit.,..I was running a 52 jet in it, it ran fine with the biturbo exhaust... But as soon as I de-restricted my air filter, It bogged down on me..Which told me that I was getting too much air, so I upjetted till it ran good again.. Which put me at about a 64 jet.. I am running a 14.12 dellorto.. Maybe thats the problem? The air intake is just too small on the carb?
Port it. Also, there are much better pipes than a biturbo. Do you know if you had the 20 mph or 30 mph cylinder to start? You probably had the 20 so going 31 is actually an improvement of over 50%.
Stock it was doing 28-29.. Is there anything you can do as far as machining the head? To get more compression?
how old is your plug? You may just be getting not great spark limiting your speed. Or your jetted to high.
You could shave the head and use premium gas. But port matching and widening the port windows by a millimeter or two would probably be more dramatic.
premium gas? really? thats your recommendation?
i use the good stuff every time, for sure, but its not adding any speed. shit.
a 52 size jet to a 64 is a huge leap. go to a 54 and keep going up until it hits right.
I have a Mamba pipe with a 14.12 carb with no airbox and I'm running a 65 jet. I am in the low thirtys with mine. I have a 42 gear in the back and a 11 in the front. I was running a 10 tooth and it made a big dirrerence when I swapped to the 11.
Steve
I also tried a 15.15 carb and it made a good difference on the top end.
definately port it some. Raise the exhause and lower the intake to reach some higher rpms and slap a 15 or 16 on it. Ditch the biturbo and get an estoril.
I only recommend premium gas IF you increase compression by shaving the head. Otherwise it does nothing.
so how do you know if you have the 20 or 30 mph cylinder? just curios?
is the intake port the size of your index or pinky finger?
The cylinder's are two different sizes.. The bore size of the 20mph one is 38.0mm and the 25-30 is 38.8mm.. I don't know if there is a way to tell just from looking at the bike and not measuring it yourself but that would be one way
I def. recommend a larger carb/intake.. not more than a 16.16 if your not kitting the ped.. some portmatching if your good with the dremel... and an estoril exhaust... bi-turbo's are for the birds.. know that with an estoril comes some fitting/welding..
Also if your tapped out with sprocket options you can try and put some Tomos wheels on it.. saw them on a general 5 star the other day.. you can get a tiny rear spoke in the back but your bottom end will probably be pretty bad..
good luck
Getting the air right is the trick. You should try a 56-58 jet with a stock 50cc and Dellorto, then tweak the air in. Trust me, it's all in the air.
Perfekt Timing Angel /
Look at the piston's dome. it will give you a number, such as 38,8 or 3-,-. That is your bore in mm.
Sometimes they do not have numbers, in which case, the only way to know is to measure it.
Add a 15:15 or a 16:16, Mamaba (or Estoril, though I personally have not tried this pipe YET) with a 38,8mm bore and a 11 X 44 gearing, and you should be somewhere around 35ish. Adjust your gearing, and you can squeeze more out of it. Do some porting, and you could probably get 'er doing 40.
I find Minarelli's aren't the fastest stock bikes out there, but they have a lot of torque/low end. If you want fast with easy and cheap mods, get a Puch.
Oh yea, and pretty much what everyone else said. Minarelli's can be funny about their air ratios.
Yea but Minarellis are just _classier_ than Puchs.
^^^ Yup!!!! They also have 'charisma'!
Much classier... And this motron was my first, so it holds a special place in my garage.. I'll probably never sell her.. and everyone and their mother owns a puch
amen
minarellis are the torquiest out there though....I'm confident enough to wager on that. I'm debating on tweeking the ports on the polini for a few more RPMs
I ported my dr kit 43mm =60cc. The exhaust is is tapered widen the window a bit. Its nice kit and bullet proof. Yeas the mamba bolts right up. 16mm intake 24mm exhaust. These are very rare but can be found in italy. -Ed
Haha, right on!
Ed,
where in Italy?!? ha
i've searched italian ebays and all over the. i can't find them.
any hints?
when juggernaught mentioned running premium fuel that was in conjunction with shaving the head. He wasnt saying that premium fuel would make it faster but that it is a needed measure when raising the compression by shaving the head in order to prevent pre-detination.
These are super rare.. you wont just find it.
I can get whatever minarelli v1 parts you need. Ed
