Puch Performance Tuning
So I just purchased my third moped last week, and I'm thinking that it needs some help so it can keep up with the hobbit and the mobylette. I got this puch and I want to build it up so it is fast and reliable. What are some good cylinder kits? I see that 1977 has that 80cc jobber, but is that thing going to give me headaches? my padre has a machine shop so fitting it should be an issue. What about exhausts? I was thinking of using a little makuni flatslide i found in his shop... suggestions would be appreciated
Re: Puch Performance Tuning
80 metra small port on an e50 is awesome. On a za50 you have to add material to the case because of the transfers. On both you have to cut the case to fit the kit. exhaust ports are angeled so a homoet 8p or a simonini but pedals might be a problem.
24mm Mikuni would be awesome with it as well but its alot of tuning and matching you will be facing with this whole setup.
But if you do, you'll be hitting 60 with an 80cc and 24mm carb.
Thanks for your input, i think I am going to give it a whirl this fall/winter.
