I ended up having to mount my 19mm Delorto carb at a slight angle (Maybe like a 20 to 30 degree) Anyways would this prove problematic?
Guess I'll just try it.
I've got mine at a similar angle cause of my reed valve intake.
Does it run weird?
i think i actually read it can be 40* off its central axis. of course i cant find the manual i read that out of... and i cant remember exactly what it said. ive never run a carb at a crazy angle like that, but i have seen some pictures of setups like that and they apparently run fine.
fact.
Cool. I was afraid that since the float works upon boyancy I was screwed. Thanks guys!
Crazy angles are no problem. Just make sure that the float stop is bend out a lil bit, so the float bowl can fill all the way.
Carb angles rule of thumb: If it doesn't leak out of the overflow-hole, you're good to go ;)
Thanks guys! The angle is not to drastic so I should be good.
http://www.morinispecial.it/manuali/dellorto_motorcycle_carburetor_tuning_guide.pdf
i didnt belive it either but its true
Some good info there thanks again!
well that answers one of my questions right there. she was running great, then something happened. not quite too sure what though.
http://i134.photobucket.com/albums/q106/aaroncant/IMGP0773.jpg
Wow. That angle's crazier than mine.
get out the protractors boys!
Haha yeah.
That looks almost identical to my angle Brian. Thanks!
