Im have a DMP stuffed crank that doesn't have needle bearing. Do i need this this? The stock crank didn't have one. I'm about to put on a 65 metra also.
Needle Bearing
Re: Needle Bearing
yes you need one.
Re: Needle Bearing
If you can get the dimensions from someone that has one you should be able to pick one up from your local bearing shop or online.
Re: Needle Bearing
Treats has them now. $6
