Re: What throttle for Mikuni Carb 24mm?
jupoloopo /
I almost forgot. You gotta find one with the hollow tensioner bolt for the cable to sit in against. If you don't get a bolt thing with it, it won't work unless you come up with an idea. I had to make one in a lathe from a large galvanized steel bolt from ace hardware.
the 1977mopeds motion pro has the bolt, I don't really know if the Treats! vortex model comes with one or not. (it's not in the picture) The CNC Throttles on ebay might come with one if you get the cable setup with it. The CNC throttle I got from ebay is the one I had to make a tensioner for.
not sure if it was started or not, but you may have to drill knarp catch on the throttle. as these do need cable knarps.
  What throttle for Mikuni Carb 24mm?Topic by: Andy Andy 08/08/08 12:48AM
  Re: What throttle for Mikuni Carb 24mm?Re: freebird freebird 08/08/08 01:00AM
  Re: What throttle for Mikuni Carb 24mm?Re: henryb henryb 09/18/09 01:56PM
  Re: What throttle for Mikuni Carb 24mm?Re: SidD SidD 08/08/08 12:25PM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 09/10/08 11:41AM
  Re: What throttle for Mikuni Carb 24mm?Re: los77 los77 09/10/08 11:45AM
  Re: What throttle for Mikuni Carb 24mm?Re: M A M A 09/10/08 12:11PM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 09/10/08 01:01PM
  Re: What throttle for Mikuni Carb 24mm?Re: Jon P Jon P 09/10/08 04:51PM
  Re: What throttle for Mikuni Carb 24mm?Re: M A M A 09/10/08 07:51PM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 09/10/08 11:10PM
  Re: What throttle for Mikuni Carb 24mm?Re: Eddie Eddie 09/11/08 12:35AM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 09/11/08 12:57AM
  Re: What throttle for Mikuni Carb 24mm?Re: mike mike 10/27/08 12:47AM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 09/11/08 02:38AM
  Re: What throttle for Mikuni Carb 24mm?Re: No Lo No Lo 09/11/08 03:54AM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 09/11/08 04:34AM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 10/27/08 03:15AM
  Re: What throttle for Mikuni Carb 24mm?Re: David David 10/27/08 03:19AM
  Re: What throttle for Mikuni Carb 24mm?Re: Aces Brother Aces Brother 10/27/08 04:29AM
  Re: What throttle for Mikuni Carb 24mm?Re: David David 10/27/08 08:07AM
  Re: What throttle for Mikuni Carb 24mm?Re: mike mike 10/27/08 12:47PM
  Re: What throttle for Mikuni Carb 24mm?Re: Sunset Paul Sunset Paul 09/18/09 03:07PM
  Re: What throttle for Mikuni Carb 24mm?Re: Sunset Paul Sunset Paul 09/18/09 03:25PM
  Re: What throttle for Mikuni Carb 24mm?Re: spencer spencer 09/18/09 03:46PM
  Re: What throttle for Mikuni Carb 24mm?Re: mattology - mattology - 09/18/09 07:59PM
  Re: What throttle for Mikuni Carb 24mm?Re: Matt Chin Matt Chin 09/18/09 08:26PM
  Re: What throttle for Mikuni Carb 24mm?Re: jupoloopo jupoloopo 09/18/09 08:37PM
  Re: What throttle for Mikuni Carb 24mm?Re: jupoloopo jupoloopo 09/18/09 08:50PM
  Re: What throttle for Mikuni Carb 24mm?Re: mattology - mattology - 09/19/09 04:31AM
  Re: What throttle for Mikuni Carb 24mm?Re: Matt Chin Matt Chin 09/19/09 12:17PM
  Re: What throttle for Mikuni Carb 24mm?Re: mattology - mattology - 09/19/09 02:24PM
