What throttle for Mikuni Carb 24mm?
Andy /
Hey guys,
I am running a Mikuni 24mm Flatside carb and of course the stock throttle assembly doesn't have a long enough pull to get the throttle slide inside the carb to open 100%
What aftermarket throttles are you using then to get that shit to work?
Unless there is some modification I can do.
  What throttle for Mikuni Carb 24mm?Topic by: Andy Andy 08/08/08 12:48AM
  Re: What throttle for Mikuni Carb 24mm?Re: freebird freebird 08/08/08 01:00AM
  Re: What throttle for Mikuni Carb 24mm?Re: henryb henryb 09/18/09 01:56PM
  Re: What throttle for Mikuni Carb 24mm?Re: SidD SidD 08/08/08 12:25PM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 09/10/08 11:41AM
  Re: What throttle for Mikuni Carb 24mm?Re: los77 los77 09/10/08 11:45AM
  Re: What throttle for Mikuni Carb 24mm?Re: M A M A 09/10/08 12:11PM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 09/10/08 01:01PM
  Re: What throttle for Mikuni Carb 24mm?Re: Jon P Jon P 09/10/08 04:51PM
  Re: What throttle for Mikuni Carb 24mm?Re: M A M A 09/10/08 07:51PM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 09/10/08 11:10PM
  Re: What throttle for Mikuni Carb 24mm?Re: Eddie Eddie 09/11/08 12:35AM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 09/11/08 12:57AM
  Re: What throttle for Mikuni Carb 24mm?Re: mike mike 10/27/08 12:47AM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 09/11/08 02:38AM
  Re: What throttle for Mikuni Carb 24mm?Re: No Lo No Lo 09/11/08 03:54AM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 09/11/08 04:34AM
  Re: What throttle for Mikuni Carb 24mm?Re: Andy Andy 10/27/08 03:15AM
  Re: What throttle for Mikuni Carb 24mm?Re: David David 10/27/08 03:19AM
  Re: What throttle for Mikuni Carb 24mm?Re: Aces Brother Aces Brother 10/27/08 04:29AM
  Re: What throttle for Mikuni Carb 24mm?Re: David David 10/27/08 08:07AM
  Re: What throttle for Mikuni Carb 24mm?Re: mike mike 10/27/08 12:47PM
  Re: What throttle for Mikuni Carb 24mm?Re: Sunset Paul Sunset Paul 09/18/09 03:07PM
  Re: What throttle for Mikuni Carb 24mm?Re: Sunset Paul Sunset Paul 09/18/09 03:25PM
  Re: What throttle for Mikuni Carb 24mm?Re: spencer spencer 09/18/09 03:46PM
  Re: What throttle for Mikuni Carb 24mm?Re: mattology - mattology - 09/18/09 07:59PM
  Re: What throttle for Mikuni Carb 24mm?Re: Matt Chin Matt Chin 09/18/09 08:26PM
  Re: What throttle for Mikuni Carb 24mm?Re: jupoloopo jupoloopo 09/18/09 08:37PM
  Re: What throttle for Mikuni Carb 24mm?Re: jupoloopo jupoloopo 09/18/09 08:50PM
  Re: What throttle for Mikuni Carb 24mm?Re: mattology - mattology - 09/19/09 04:31AM
  Re: What throttle for Mikuni Carb 24mm?Re: Matt Chin Matt Chin 09/19/09 12:17PM
  Re: What throttle for Mikuni Carb 24mm?Re: mattology - mattology - 09/19/09 02:24PM
