I got the malossi case for the vespa and a complete kinetic setup with cdi flywheel, and both coils in the stator however the kinetic unit dosent bolt up to the malossi case do I need to make a bracket to hod the coils in place please help this is getting hell spendy
vespa malossi case
Re: vespa malossi case
bump help
probably only works vespa CDI not kinetic.
Re: vespa malossi paste
actually, as far as i know, the malossi cdi for that case is no longer made. i run ktm dirtbike cdi on mine. tons of fabrication. :\
do you think I could make the kinetic cdi work? (that was the one benji suggest I get)
