I'm mounting up my proline this week, as soon as my engine goes back on the frame, (watiing on gaskets) and I realized I have to chop the kick stand in half and bend it to make it a side kick, or else It wont fit with the pipe. The pedal shaft also has to be extended, or I have to dicth the pedals.
Any good methods of extending pedal shafts?
Pro's and con's of having no pedals?
I'm also going to run a speed increase test, running the old pipe then the new pipe. I'm interested to see the difference.
Setup:
65cc DR kit
ported, case matched, intake drilled to 13.
13.13. carb.
Hi-flo filter.
Simonini proline (the long pipe).
Stock variator/pulley.
I'm thinking I may clip my stock springs though for low end if I need it.
Also, I was looking at the frame and doing some disassembly work last night, and I realized that I cant remove the rear rack, because of the way the seat post sits. Anyone else with a ciao, how did get the seat to affix to the frame?
