Re: Puch head milling
Flagrant - /
I was going to say that those heads are easy to get. At least take it down to the fins. I f the piston hits the head use a dremel or files in the squish band of the head until it doesn't hit You can put a dye like prussian blue on the piston and after torqueing down the head take it off and the dye will show where the head is being hit by the piston
