Did you clean your air filter? Changes are your carb and airfilter were both gross. You cleaned the carb and now it's getting more gas, but your air filter element is all rusty and gnarly...
If it's a maxi, those airboxes are hinged and snap, but they seal them. You can run a blade around the edge to cut the seal, pop it open and then either replace or clean your air filter element...
