16mm carb to big for 50cc?
is it?
have a 16mm i got for when i throw an airsal kit on it.
put on just the carb today and is runnig silly.
i think the slide is sticking a bit
and the throttle responce is really slow.
i think i am about 2 jets too high. (going to fix that later today i think)
Re: 16mm carb to big for 50cc?
nah , ur just jetted wrong
a 16 will run great on 50cc.
could my undrilled intake (dia. of 14mm) have anything to do with anything goofy?
may sounds retared but it is way better to ask before i give up on it....
is it possible for my slide to be a little sticky?
the intake will restrict your setup for sure, enough to where you won't notice any real gains from that carb. Bore it out or put a better intake on there. Is your pipe restricted?
as for the slide why don't you take the air filter off and look to see how the slide is traveling- that is an easy one.
are you 4 stroking at top speed? what are you plug chops like? Carb cleaner air leak tests? Try running without the air filter and just the box.
