Re: A35 on a batavus hs50
♣Slew Foot♣ /
i can make that M48 run 30-35 mph with nothing more than a file and screwdriver. a batavus doesn't lend itself to engine swapping easily,
a pug or moby would be a closer match and you can variate it by replacing the slide mounts with nylon spacers and locknuts on the engine mount and a spring where the belt tensioner adjustment bolt goes.
add a doppler and av7 and variate....
