What is the bigest front sprocket i can run without cuting anything?
What is the smallest rear sprocket i can just bolt on with no cutting etc.?
I want the easiest option.
Thanks
Thanks
Speaking from experience (i have a streetmate R). The biggest you can go on the front sprocket is 26 w/o cutting anything. We tried fitting the 27, but there was too much cutting/modification needed to get it to work.
For the rear sprocket, the smallest i've run is the 22. The 26 front and 22 rear seems to be a great setup and everything is bolt on.
The holes in the rear sprocket has to be drilled out for the larger bolts in the Streetmate R hub before it can be used. Tomos does not have any rear sprockets for the Streetmate R yet.
The 27 will fit on the front but it will rub on the plastic engine side cover for a few hundred feet then it will have just right amount of clearance.
If you have a 24 tooth rear sprocket, I will buy it from you and you can purchase the 22 from mopedshop.com.
a55er is that the best sprocket setup. I am 130 so what do you think would be good for me.
Thanks
