Re: dellorto Q's for the dudes out there
Eric P /
Test for spark and compression. Put your thumb over the sparkplug hole and have someone crank it over. if your thumb is pushed off, you have decent compression. With that said and done, pour a little gas into the spark plug hole, turn it over like you're gonna start it w/o the spark plug a couple times, then put the plug in and turn it over. It should fire up. If not, I would check the timing. If both those tests pass, then clean the carb again.
And to answer your question, no there shouldn't be gas coming out unless the engine sucks it out.
  dellorto Q's for the dudes out thereTopic by: Kim Jong illest Kim Jong illest 07/26/08 05:44AM
  Re: dellorto Q's for the dudes out thereRe: BootyClap Ninja BootyClap Ninja 07/26/08 06:29AM
  Re: dellorto Q's for the dudes out thereRe: Kim Jong illest Kim Jong illest 07/26/08 07:58AM
  Re: dellorto Q's for the dudes out thereRe: johnny johnny 07/26/08 08:12AM
  Re: dellorto Q's for the dudes out thereRe: Kim Jong illest Kim Jong illest 07/26/08 08:55AM
  Re: dellorto Q's for the dudes out thereRe: elliot in england elliot in england 07/26/08 09:21AM
  Re: dellorto Q's for the dudes out thereRe: Responsible Jon Responsible Jon 07/26/08 10:32AM
  Re: dellorto Q's for the dudes out thereRe: Eric P Eric P 07/26/08 11:10AM
  Re: dellorto Q's for the dudes out thereRe: Satan 666 Satan 666 07/26/08 11:52AM
  Re: dellorto Q's for the dudes out thereRe: Tyler Jacobson Tyler Jacobson 07/26/08 02:44PM
  Re: dellorto Q's for the dudes out thereRe: Tracy Tracy 07/26/08 03:52PM
  Re: dellorto Q's for the dudes out thereRe: .Allen Schlung .Allen Schlung 07/26/08 05:21PM
  Re: dellorto Q's for the dudes out thereRe: Kim Jong illest Kim Jong illest 07/26/08 06:15PM
  Re: dellorto Q's for the dudes out thereRe: ottoman ottoman 07/26/08 07:26PM
  Re: dellorto Q's for the dudes out thereRe: Kim Jong illest Kim Jong illest 07/26/08 06:42PM
  Re: dellorto Q's for the dudes out thereRe: Saabsonettguy . Saabsonettguy . 07/26/08 07:24PM
  Re: dellorto Q's for the dudes out thereRe: Kim Jong illest Kim Jong illest 07/26/08 07:32PM
  Re: dellorto Q's for the dudes out thereRe: Kim Jong illest Kim Jong illest 07/26/08 07:41PM
  Re: dellorto Q's for the dudes out thereRe: ottoman ottoman 07/27/08 02:58AM
  Re: dellorto Q's for the dudes out thereRe: elliot in england elliot in england 07/26/08 10:10PM
  Re: dellorto Q's for the dudes out thereRe: Kim Jong illest Kim Jong illest 07/26/08 10:42PM
  Re: dellorto Q's for the dudes out thereRe: Air Bud Air Bud 07/26/08 11:30PM
  Re: dellorto Q's for the dudes out thereRe: Kim Jong illest Kim Jong illest 07/27/08 12:02AM
  Re: dellorto Q's for the dudes out thereRe: Kim Jong illest Kim Jong illest 07/27/08 03:07AM
  Re: dellorto Q's for the dudes out thereRe: Tracy Tracy 07/27/08 04:00AM
  Re: dellorto Q's for the dudes out thereRe: Kim Jong illest Kim Jong illest 07/27/08 04:36AM
