so my techno circuit is coming in on mon. should i get a bigger sprocket?? since circuits are great for low end. i should up the rear sprcket to compensate and get a little better top end correct?
that is if you are talking about the front sprocket.
it is reverse for the rear....smaller = higher top speed.
You should rejet before you mess with sprocketage, dood.
yeah i upjetted one size and its all stil stock. but when the techno goes on ill up jet one more size.
