Re: Bravo Clutch
the spring is fine you need to take some aluminum oxide sand paper and ruff up those pads and also the surface they contact inside the bell then rub them down with rubbing alcohol but be careful not to take too much out of the pads and also if you need to take apart the clutch put it in a vise clamp that nut fucking sux to take off. If you need anymore help let me know.
Joey
