ideas on shaving an av7 head
I cant be without my ped for as long as a machine shop will take to shave my cylinder head.
Flat surface and sandpaper right? anybody have good results with something else? has anyone ruined a head trying this?
thank you in advance.
Re: ideas on shaving an av7 head
get a second head.
Then do this to it.
1.5mm squish is optimal ive heard on racing moped engines
I know the specs.
I am looking for a way to do it at home. I have heard of it being done with patience, sandpaper and a flat surface.But I want an idea of the success rate of this.
i have done it with sand paper and a flat surface. it isnt fun or fast, but it does work. you have it right, patience is the key.
listen to bret, get a second head just in case. check the buy/sell forum.
ive done this on a bat head but i didnt do it for optimal squish, there is one on a bat head, so i just got super high comp, i wet sanded after sanding it down till it was smoothe as my ass
lee's anus is leefungchowOG /
use a mirror or piece of glass and tape some emery cloth to it and watch a movie or something while you do it. it will take a while. use 80 grit then 150 grit.
