rear sprocket teeths amount?
isnt it less teeth on my rear sprocket that will be faster on the top end
Re: rear sprocket teeths amount?
Ben Van Zoest /
That's what they say..
slower acceleration...
coricidin /
well i already have 22 on my rear sprocket and the rim is made so i dont think it can get smaller
how many teeth would i need on the drive sprocket for more top end (this is a a3 bullet tomos)
go with a 1 or 2 tooth sprocket you should get really good top end
i just put a 27 th front sprocket on my tomos and gave me an extra 5mphs stock 24 in the rear
The best way for free speed is to grind off some of the teeth of the rear sprocket, thus lowering your rear tooth count = bam more speed.
oh, plus a 2% mix of apple juice.
lolz gridning off the teeth? that wouldnt do anything expect fuck up the chain...
it would still be the same distance the chain travels cause the sprockets circumfrence is the same as it was prior to that
You forgot the apple juice in combo with the teeth grinding - that's what makes it all work!
shit... sorry bert im just so ignorant with peds
3% apple juice and grinding some teeth will make you go faster
2% could run a little lean
Apples are good for teeth but if you want serious speed get gold caps encrusted with ice.
ok i grindeded off my teeth now what do i eat the apples with?
dont forget to weld in the spark plug so u dont leak compression and get an O pipe for ultimate backpressure
