bogging at WOT
garelli running polini kit 21mm dell and proma with a 90 jet...
do i need to down jet a little?
Re: bogging at WOT
Yes and adjust the needle down. Sometimes can run up to a 110 main.
Re: bogging at WOT
ERIC WOOLF /
YES YOU DO. JUST LEAN THE NEEDLE DOWN ONE KNOCH, CLEAN YOUT PLUG OR CHANGE TO A NEW ONE AND RUN THE SHIT OUT OF IT FOR A BRIEF TIME, TURN OFF AND CHECK THE PLUG, IT SHOULD BE A NICE TAN TO DARK BROWN. IF IT'S STILL BLACK AND OILY GO DOWN ANOTHER KNOCH. YOU WILL KNOW IF IT'S RUNNING RIGHT RIGHT AWAY
Re: bogging at WOT
the needle is already down all the way.. so should i jump down to an 86 or something?
Re: bogging at WOT
is it bogging or four stroking? before down jetting, try upjetting for kicks. maybe a 100, 110. better safe then sorry.
