Please checkout the picture.
I wanna try to get this to fit on the v1's I guess the timing on the intake/carbie side should be out all of the 360 degrees?
If the spacing is close enough maybe anything can be made reed valve? Just throwing it out there since you must have a v1L with this you just have to mod.
To much space will have no bottom end?? Alot of crank case volume or not enough?
Just comment.
Thanks, Ed
