Re: WTF, more hobbit pipes!
Drocnoc /
- Proma Conica -
81 PA50 II
Mods:
Boyesen Reeds - Stock
Removed Breather Tube
My hobbit was running 'ok' before. Four stoking alot and running very rich. It would get up to 30 but would four stoke and not go much past. Also it didn't like to idle, but i think that was an intake air leak.
When I installed the pipe I put Red high temp RTV (as mentioned by a fellow MAer) on all intake surfaces (reed block-crankcase, intake-reed block, carb-intake).
With the new pipe and intake seal the hobbit runs awesome. It only four stokes when going down hills at full speed. Not sure about the top speed as my speedo cable broke. I assume its around 35 or so judging by traffic.
Low end is really sluggish but once its start moving the mid pull is awesome. Good top speed cruising.
The low end is the biggest issue right now. I think that is attributed to my low compression. the last test i did it only had 90psi. I have new rings and gaskets to rebuild it.
I also was to check out the variator, I don't think its operating at 100%. I think I hear the plastic caps rattling around in there.
Those are the next projects.
But as far as the pipe goes: I would say it was well worth it. Install was easy, build quality is good and it very much improved my ped.
-D
  WTF, more hobbit pipes!Topic by: Eric Eric 07/16/08 09:40PM
  Re: WTF, more hobbit pipes!Re: davey davey 07/16/08 10:35PM
  Re: WTF, more hobbit pipes!Re: Raymond Rexroad Raymond Rexroad 07/17/08 12:14AM
  Re: WTF, more hobbit pipes!Re: Pvt Joker Pvt Joker 07/17/08 02:11AM
  Re: WTF, more hobbit pipes!Re: Graham Motzing Graham Motzing 07/17/08 02:51AM
  Re: WTF, more hobbit pipes!Re: Drocnoc Drocnoc 07/17/08 12:32PM
  Re: WTF, more hobbit pipes!Re: davey davey 07/17/08 02:16PM
  Re: WTF, more hobbit pipes!Re: Drocnoc Drocnoc 07/17/08 02:56PM
  Re: WTF, more hobbit pipes!Re: davey davey 07/17/08 03:04PM
  Re: WTF, more hobbit pipes!Re: freebird freebird 07/17/08 05:56PM
  Re: WTF, more hobbit pipes!Re: ©h®i$ Stewart ©h®i$ Stewart 07/17/08 05:59PM
  Re: WTF, more hobbit pipes!Re: freebird freebird 07/17/08 06:00PM
  Re: WTF, more hobbit pipes!Re: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 07/17/08 06:04PM
  Re: WTF, more hobbit pipes!Re: Pvt Joker Pvt Joker 07/17/08 09:39PM
  Re: WTF, more hobbit pipes!Re: freebird freebird 07/17/08 10:29PM
  Re: WTF, more hobbit pipes!Re: Pvt Joker Pvt Joker 07/18/08 01:24AM
  Re: WTF, more hobbit pipes!Re: davey davey 07/19/08 08:32PM
  Re: WTF, more hobbit pipes!Re: davey davey 07/20/08 04:20PM
  Re: WTF, more hobbit pipes!Re: santini santini 07/21/08 09:50PM
  Re: WTF, more hobbit pipes!Re: davey davey 07/21/08 11:32PM
  Re: WTF, more hobbit pipes!Re: Ben Ben 07/22/08 12:28AM
  Re: WTF, more hobbit pipes!Re: davey davey 07/22/08 12:32AM
  Re: WTF, more hobbit pipes!Re: Ben Ben 07/22/08 01:34AM
  Re: WTF, more hobbit pipes!Re: Drocnoc Drocnoc 07/30/08 12:57PM
  Re: WTF, more hobbit pipes!Re: Drocnoc Drocnoc 07/30/08 01:06PM
  Re: WTF, more hobbit pipes!Re: Ben Ben 07/30/08 02:33PM
  Re: WTF, more hobbit pipes!Re: Brad Brad 08/02/08 09:53AM
