What does changing the notch setting on the slide needle do exactly. I have a 12mm bing on my za50 I'm just trying to set it up correctly.
Bing slide needle
Re: Bing slide needle
Forum search for Bing needle
changing the needle setting changes the air mixture from 1/4 to 3/4 throttle. The higher the needle (lower the clip) then the richer the air mixture. General bings run best at one of the middle settings with the normal range of jets.
so it has nothing to do with WOT
