Clutch spring set up
ERIC WOOLF /
After a cruse today I found that when I hit the gas it will acclerate slowly. If I turn in the clutch spring screws will this make the bike launch a bit faster?
Re: Clutch spring set up
Do a search then ask for help. R&D is a lot of work time money and net working. Do a search AK the big R in R&D then ask for help.
yes it will cause the clutch to engage farther into your power band , kinda like when you slip the clutch on your car to get off the line faster without spinning the wheels
