Puch bogs+stalls when starting from complete stop
Hello,
I have a 1979 Puch Magnum MKII.
Upgrades:
65cc metrakit cylindar/piston
stock 50cc head
dellorto 16.16 sha carb #76 jet pantyhose filter
custom 15mm intake
bullet exhaust
everything else stock
The issue is:
Starts no problem, runs great, plug chop on the dark tan side, idles a little high.
Out and around it is great (hills + flat land), when I come to a complete stop it idles fine but when I give it gas to start going it bogs down and stalls. It start back up just fine, but to get past the stalling I need to keep feathering the gas at the stop (traffic light). Fuel seems to be collecting on the surface of the filter not soaked but 5-10 drops worth which leads me to believe it is running too rich at idle. Is this correct?
I figure the resolve is me needing to adjust the throttle slack and idle setting but I just want to confirm before I stare making these adjustments. If so, any suggestions?
Also I am premixing (removed oil injection system) It is mixed 32:1, I've been breaking in the kit but it seems to broken in now, I'm just running it out to make sure. The next tank will be mixed 40:1
_Tim
Re: Puch bogs+stalls when starting from complete s
Also it is a za50 engine
sorry
your correct adjust the idle and the slack!
Word!
Thanks
