Magnum top-end advice
I have a 78 Swinger which did have a 65 metra until I broke off an exhaust stud and then fucked up even more by having someone try to drill it out. Anywho, my current setup is a Magnum top-end, a case matched case(for a 65 metra), 16 Sha, Bi-turbo, and 17/41 gearing. My acceleration is great, but my top-end blows. Having touched close to 50mph with the metra I was wondering if widening the transfers on the Magnum top-end would help me push past 33mph! Does that speed sound right for the setup anyway?
Thanks,
Marsh
Re: Magnum top-end advice
well if u can afford to lose some bottom gear higher.
are you running an e50 or a za50? i just picked up a magnum with a bolted on metra 65. and a homoet 6p and 21 dellorto, advanced timing... gearing 18/36 no porting no case matching just bolted on.. breaking it and running it real fat... hit 54 last night... gps'd it..
magnum cylinders work awesome if you add one or two more base gaskets, and run a crazy high comp. head, no head gaskets, so maybe mill a stock one for hi compression if you can.
yeah. ive got a intake/exhaust ported one.
~SABAT!
