start your bike put carb cleaner on all surfaces that meet and see if it bubbles if not u have something different going on if it does
4 bolts and as for advice lefty lossy righty tighty, also make sure u have replacement seals. then grab your head and pull back (should slide right off). then maybe put a little oil in your cylinder and pull it off take off seals. u will need a scraping tool just don't scrap the metal to much put seals on put piston in cylinder (oil cylinder walls) put head on cylinder. put washers on studs, put bolts on studs. tah da simple
