Re: When is using a PA50 II motor NOT indicated?
Mike Bartell /
Use the PA50II's outer variator ramp plate, intake and reeds for a start. It'll give you a boost with your stock carb. Plus, it's pretty easy to swap over. You may have to file off the flat spot on the variator plate, to make the center round so it will fit on you shaft, and I think there is a pin on the engine case, but I don't remember off the top of my head. Basically if something gets in your way- make it fit.
