Does a Simonini Circuit fit on a Ciao without getting in the way of the pedal arms? I just need an answer from someone who's done it.
No. Bend the pedal out a bit and its fine.
I had a problem with it hitting the chainring on the peddle shaft, but there might be a work around for it, IDK.
None of the euro guys run pedals, so alot of the pipes have issues.
Polini Top One, is a great mid-range pipe with "no" clearance issues.
the real Q is does a ciao fit on a simonini. i like pedals. and kickstands.
Just bend your kick stand and pedal arms. problems solved. The clearence issue is pretty small. A vice and a torch will solve it all,
