Just came in the mail today. Such a sick looking 50cc jug. This is gonna be one 50cc to really get the groceries!
I'll post pics later tonite!
peace
crackstar the excited
peace
yup. That setup will be toxic. The French sure do 50cc right!
Fkyeah!
Its really gonna be fratalian! Polini cases, malossi jug, dellorto carb, doppler crank, doppler clutch pulley, malossi varplus on a hacked stock vario, malossi CDI a truly multinational effort,
I hope you post a review when that thing is running. I just know its going to be sick.
Um, I don't see a pipe in that list... It's kinda more important than anything else you just listed.
Oh, yeah the pipe! I'll be using a second generation Crackpipe!
please supply 1000% more details kthx.
I was really worried that you were going to use a stock pipe.
First generation is almost done, the header section is all welded up, just waiting for the oportunity to cut the new diffuser cones. First gen went thru a total redisgn once I realized the the porting on my AV7 engine just didn't have the time/area to support the RPM i designed the pipe around. Plus I got some new books! Gen II will be designed totally around this GR1 Cylinder but essentially the same. I have been on this build my own pipe kick since I read that most if not all Moby performance pipe either interfear with pedals or variator movement. I want a pipe that folds and fits under the bed! Imagine out, to the right, up, over, then down and under.....
i have the watercooled version of that kit. killer for sure.
I'm running the doppler ER1 pipe with the stock kick stand without a problem!
I hear the Malossi GR1 50cc kit is super sick, have fun! I'll probably switch over to that once I seize my Malossi 70cc (if it can not be had again).
I dont see a real head on that list either! Doppler O ring yo!
