trans fluid
just a random ?
what kinds of trans fluids are u using i just spent $20 on 2 quarts of cam 2 and it wasnt even that great would love to know
Re: trans fluid
Just regular old ATF
Re: trans fluid
10w30 synthetic.
Re: trans fluid
motul transoil or transoil expert is worth the $$
Re: trans fluid
before my ped started leaking i used penzoil and it worked great once i get it fixed im gonna try a different one every time i change fluid
Re: trans fluid
My 2008 Tomos Streetmate is Type F stock, but the shop manual says two options are available. Mercon ATF will allow the bike to shift into second gear a little sooner, while 10W-30 motor oil will hold first gear longer for better acceleration. It also says 10W-30 isn't recommended in colder climates because of harder starting. I've only used Mercon becuase I'm more certain of the quality. Type F fluid is tough to find and when you can it's usually a bargain brand I've never heard of.
